JD 4100 3PH arms hitting tires
Status
Not open for further replies.
   / JD 4100 3PH arms hitting tires #1
acs55812
Duluth, MN
I haven't had time to check the owners manual yet but has anyone had a problem with the 3PH lower arms hitting the bars on ag tires if something (brushcutter) swings to one side?
   / JD 4100 3PH arms hitting tires #3
Didn't this question just get a good response for you? /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/confused.gif
   / JD 4100 3PH arms hitting tires #4
actually the one in attachments was a mistake----I meant to put it in a JD forum but screwed up /forums/images/graemlins/confused.gif
   / JD 4100 3PH arms hitting tires #7
I have a 4110 which is almost the exact same tractor. You need to adjust the turnbuckles to make it fit right. And you also need to put the pin in the rear hole on the arms so it will pick the brushcutter up high enough. I have the R4 tires and it don't hit them even.
   / JD 4100 3PH arms hitting tires #8
Status
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2012 AMERITRAIL, INC. 30 T/A GOOSENECK TRAILER (A52472)
2012 AMERITRAIL...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2013 PITTS TRAILER 48X102 3-AXLE STEP DECK (A52472)
2013 PITTS TRAILER...
