JD 4100 3PH arms hitting tires
Status
Not open for further replies.
   / JD 4100 3PH arms hitting tires #1
acs55812
Duluth, MN
I haven't had time to check the owners manual yet but has anyone had a problem with the 3PH lower arms hitting the bars on ag tires if something (brushcutter) swings to one side?
   / JD 4100 3PH arms hitting tires #3
Didn't this question just get a good response for you? /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/confused.gif
   / JD 4100 3PH arms hitting tires #4
actually the one in attachments was a mistake----I meant to put it in a JD forum but screwed up /forums/images/graemlins/confused.gif
   / JD 4100 3PH arms hitting tires #7
I have a 4110 which is almost the exact same tractor. You need to adjust the turnbuckles to make it fit right. And you also need to put the pin in the rear hole on the arms so it will pick the brushcutter up high enough. I have the R4 tires and it don't hit them even.
   / JD 4100 3PH arms hitting tires #8
Status
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
