JD 4052R vs 4066R vs 5065e
   / JD 4052R vs 4066R vs 5065e #11
Lots of people like them. I’ve never cared for the closed in feeling.
Winter here lasts four or five months. It gets old being out in the elements while sitting on tractor. I welcome the change.
   / JD 4052R vs 4066R vs 5065e #12
I'm pretty sure the 4000 series are mostly made in the US while the 5000 series are imported from India.
   / JD 4052R vs 4066R vs 5065e #13
Hi Guys, I am getting ready to pull the trigger on a new tractor for maintaining 100 acres in PA. Its about 1/2 open, 1/2 wooded. Plan is to raise some horses and maybe a few cattle. I will use the machine for general purpose tool around the property for grading, material movement, quite a bit of mowing, etc..
I had my heart set on a 4 series but after getting quotes from the JD dealer, I couldn't believe the current pricing.
I asked for quotes on the following:
4052R with Loader, Bucket, and Forks
4066R with Loader, Bucket, and Forks
5065e with Loader, Bucket, and Forks
The 4052 came in at 57K out the door with PA taxes
The 4066 came in at 64K out the door with PA taxes
The 5065 came in at 52K out the door with PA taxes
Clearly the 5 series is allot more machine, and it also seems like the JD guys are pushing me towards that. The discounts offered on the 4 series were < 10% of list which I expected much better. I figured it must be the state of the market.
I hadn't plan to, but now I am going to price Kubota, New Holland, and Massey..
My question is does a 5 series seem like too much machine, will it be too big to be effective for the smaller jobs if I went that way?
Does this pricing align to what others are seeing elsewhere?
Any advice is appreciated
Thanks.
I suspect based on those prices those are cabbed tractors, and in the case of the 5065E, a cabbed MFWD tractor with the PowrReverser transmission? If so, that sounds about ballpark with sales tax added in. If these are open station units, the pricing is very high. I don't know Pennsylvania law but here in Missouri if you are raising cattle, you would qualify for an ag sales tax exemption. 4 series machines are expensive compared to 5Es, this has been true even before the pandemic.
The 5 series is a somewhat larger tractor than the 4 series, it is mainly taller and heavier. In the case of the MFWD units, the planetary axle 5 series units have a noticeably wider turning radius than the bevel gear 4 series units do. (2WD 5Es have about the same turning radius as a 4 series unit.) The 520M loader on a 5E is much stronger and has a lot longer reach than the 440R on the 4 series. You will be able to handle round bales except the heaviest 5x6s or silage bales with a 4 series tractor. However, it will be easier to handle bales with the 5 series tractor, particularly if you have uneven terrain. You can feel you have a good amount of weight on a large frame compact when handling a typical 800-1200 pound dry hay 4x5 or 4x6 round bale, but a full sized utility tractor will pick that up and walk away with it like it picked up a small square bale.
I have a 5075E on 80-some-odd acres where about 65 acres are open. It works very well for me. It works well for running a rotary cutter, maintaining the >500 yard gravel driveway, haying, handling round bales, handling materials (I also have a set of pallet forks), and general utility work. I don't find this too big since I don't try to do something like finish mow with it. I was initially looking at a larger compact, specifically the 4 series Deere, after using a blue tractor of the same size and finding it a whole lot handier than two very similar utility tractors I had run before, an open station MFWD Deere 5410 and its cabbed replacement, a 5083E. I ended up splitting the difference and keeping the size, power, and bale handling capability of the full sized utility tractor but the maneuverability of the compact by getting an open station 2WD unit as it turns almost as sharp as the 4 series does and can fit into tight spaces in buildings jockeying around implements. The dry clutch transmission is easier to feather to creep up on something with pallet forks compared to a wet clutch unit, and with loaded tires and something on the 3 point, the tractor works well picking up anything as heavy as the loader will lift. That is exactly what I was looking for in a tractor and why I decided on this specific configuration. I would have been fine with a cabbed MFWD unit of this size as well but it would have been less "handy" and cost over $20k more.
The other question I have is this seem like accurate decent pricing? As I mentioned, I certainly expected more than 8 or 9% off list, but is the market doing this or do I just have a bad dealer?
Its the market. Supply chain problems have limited supply. Compact tractor demand remains robust.
You should also shop Kioti, LS and Branson from Korea IF these brands have stable dealers near you. Korean manufacturing labor is paid 50% of what Deere pays its union work force. Japanese manufacturing labor is paid 70% of what Deere pays its union work force. Labor costs strongly influence tractor prices.
Start with the nearest dealer and work out.
Transporting a tractor for service is expensive and inconvenient, whether you trailer it or the dealer trailers it.
Fifty acres are open. Will the cattle and horses graze this fifty acres, in which case tractors ability to move 900 pound to 1,600 pound round bales of hay may be your controlling application, or will you have three to four paddocks, raising feed in one paddock, rotating animals periodically?
What is the plan for the open fifty acres?
Thanks for your responses.
The open 50 acres will be either kept in Hay or fenced into pasture for Horses/Cows. I am not sure if I will eventually hay myself. Whether I hay myself or purchase hay, I will be using Round bales, you're correct that may be the controlling application.
So I did get additional pricing today from Kioti (DK and NX), New Holland (Workmaster 55 and Boomer 55) and Kubota (Grand L and MX series)
I would be happy with any of these. I've owned New Holland TC's previously and they were great. However, the Kubota Dealer is by far the closest to me in PA (7 miles). The Kubota Dealer also said they would honor my membership to the NCHA (National Cutting horse association) and give me 20% off list. This makes the Kubota a no brainer for my situation I believe.
My final decision is whether to order an MX6000 or Grand L6060. The Kubota Dealer has told me Kubota has a price increase planned in 2020 and that if I order by EOY, they will be taking orders at current prices. The one thing that might still be an issue is they won't commit to an actual delivery date, but I may be able to deal with this in my situation. I will ask for the right to cancel if they can't deliver within 6 months (or something similar).
So based on these prices, the difference between a John Deere 4052R and Kubota MX6060 is literally $17K for same machine. If I bumped that up to the more correct comparison of a 4066R, its > 20K. I wanted to purchase Deere, but this is ridiculous.. it will be Kubota..
   / JD 4052R vs 4066R vs 5065e #15
I am age 74.
If you plan to tractor into old age buy a Kubota Grand L over the equivalent weight MX tractor. I have owned two economy tractors. I occasionally operate Deere economy tractors for my (even) older neighbors. I now own an open station Kubota L3560 Grand L. I am sure the deluxe Grand L features will add at least six years to my tractoring time. WELL WORTH THE MONEY.
If you will be farming for profit on your land you may be sales tax exempt for your tractor.
Discuss sales tax exemption with your dealer.
   / JD 4052R vs 4066R vs 5065e #16
The Kubota Grand L is a better direct comparator to a Deere 4R, the MX is a more basic tractor. However, there doesn't really seem to be anything missing in the MX6000 (the gear drive MX5400 is missing synchros on 1st and 2nd though.)
An MX would be fine to handle all but the heaviest round bales but making them with one would be asking a lot. You could probably do it with a Haybine and a 4x4 baler but most anything else would probably give it more than it wants. You would do better with a 75+ HP utility tractor if you ever really intend to make round bales.
I should have told you that you are correct on the models,, pricing and transmissions. The 5065E pricing is a cabbed 4wd tractor with the PowerReverser. The two 4 series are both cabbed tractors.
   / JD 4052R vs 4066R vs 5065e #18
If there is a Rural King store within a reasonable distance from you, I’d check them out. The RK55 tractor sounds like a perfect fit and will save you thousands of dollars over the previously mentioned tractors. Even the RK37 will work up to about an eight foot bush hog. The lifting capacity is also greater on the RK37. I was shopping around for a similar size tractor as you and thought I would check them out. After much research and test drives, I have a RK37 cab tractor with hydrostatic drive on order. I added the backhoe and a front grapple. This tractor will work alongside a 75 hp case and a 141 hp Kubota. I will never ever never ever buy another case/new Holland tractor again. It is total junk. Stays broken down more than it is running. There is absolutely no where you can stand around that tractor, including on the roof, that you cannot touch a component that has failed. Junk. Good luck and enjoy your new tractor!
   / JD 4052R vs 4066R vs 5065e #19
Note the letters E and R in the codes. E denotes economy,R denotes performance.
   / JD 4052R vs 4066R vs 5065e #20
I bought an LS MT352 with cab out of state had it shipped no taxes either. So that paid for an implement and I got a great deal.
The LS isn't a Deer but its as heavy as the 5 series you're looking at for 1/2 the price and all the bells and whistles. It's tight getting in and out but I'm not that big a fella so something to consider.
JD workers were just on strike for a pretty long time I'm guessing that's causing some issue supply. Like anything else low supply high demand you gonna pay more. In the 50k range ouch I'd be looking around. The Kubota and Kioti likely similar in price. Kubota is a premium tractor tho... LS gonna be budget but you get a lot for your money and standard on LS is premium on most other tractors.
40' Sea Container (A55272)
40' Sea Container...
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
Pair of 10' Fork Extensions (A57149)
Pair of 10' Fork...
