JD 4052R third remote add on kit
   / JD 4052R third remote add on kit #1
elginfarm
Bronze Member
Southwest suburb of Chicago Area
JD 4400
Hi All,
I am trying to locate the JD parts kit or part# for an add on kit of hoses and fittings to extend a rear remote to the front . (fittings, hoses etc.) or a reasonable alternative. I could order hoses from Discount Hydraulic Hose, but I need a bulkhead fitting for the front of the tractor. Any help or suggestions would be greatly appreciated. Thank you.
   / JD 4052R third remote add on kit #2
just get the 3rd function kit from wr long . it comes with everything needed and isnt hard to install . it runs about a 1000.00 but its complete.
i just put one on my cousin 4520 and other than having to pull the seat it was a easy install .
edit , it occured to me that you may have just been wanting front hydraulics , not necessarily a 3rd function. if that all you want then get the appropriate hoses made at napa and route them to the front . im sure you can find a generic bulk head plate online.
   / JD 4052R third remote add on kit #3
You have the 3rd SCV and the rear remotes now? And you want to feed (extend) the rear remotes to the front of the tractor, or to the FEL?
I extended my rear remotes from my 3rd SCV to the front of the FEL so I could operate a grapple on my forks. Not sure just what you have in mind. I don't have a bulkhead fitting.
   / JD 4052R third remote add on kit #5
Thanks chevyman29. Will look into that bracket.
   / JD 4052R third remote add on kit #6
No problem.
You should be able to get the bulkhead fittings wherever you get your lines made
   / JD 4052R third remote add on kit #7
I ran hoses from the rear 3rd SCV to the mid SCV bulkhead. From there I used the JD loader 3rd SCV hardlines and hoses.
Thanks everyone. I do already have the third remote. just asking for advice on running the hoses to the front. Chevyman, thanks for the bracket info.
   / JD 4052R third remote add on kit #9
I ran the two hyd hoses to the front along the left side of my 4300. Put quick connector couplings at the FEL frame to tractor mounts. Works quite well.
To calculate length of hyd hoses needed, I ran the garden hose through that route and marked where the couplings needed to be, then bought the right length hyd hoses.
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
Cat F30 Grain Platform (A49339)
Cat F30 Grain...
2025 Swict 84in Bucket Skid Steer Attachment (A46683)
2025 Swict 84in...
Set of (2) Polaris Full Soft Side Doors (A49339)
Set of (2) Polaris...
2005 Salem LE Travel Trailer (A49339)
2005 Salem LE...
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
