JD 4010 Fuel Injection Pump Issues
   / JD 4010 Fuel Injection Pump Issues #1
Still8nn
Rual San Patricio County TX
1949 Ford 8N (used most often)
I have a John Deere 4010 with a Roosa-Master Injection Pump. This pump has the governer built into the unit and the governer has broken apart and plugged the return line. After I clean out the return line, the engine runs fine again for awhile. My question is . . . Can the governer assembly be replaced without a complete injection pump overhaul? $:(
The pump only has about 500 hrs. on it since the last overhaul.
So far I have been unsuccessful finding replacement parts for this injection pump. Any info is appreciated.
Tom
   / JD 4010 Fuel Injection Pump Issues #2
with only 500 hrs since the rebuild it should still be under warrenty, there is a place up here in canada where i get most on my parts for my ford 5600 and my kubota m8950 dt its a new and used tractor part place and it s called sexsmith used parts the nuber is 1 800 340 1192 but wont be open until tomorrow as this wekend is our labour day holiday i hope this works for ya .don [the bear]
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
JOHN DEERE 7230R TRACTOR (A60430)
JOHN DEERE 7230R...
1977 Heil 6,300 Gallon T/A Tanker Trailer (A59230)
1977 Heil 6,300...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
