JD 4010 Fuel Injection Pump Issues
   / JD 4010 Fuel Injection Pump Issues #1
Still8nn
Rual San Patricio County TX
1949 Ford 8N (used most often)
I have a John Deere 4010 with a Roosa-Master Injection Pump. This pump has the governer built into the unit and the governer has broken apart and plugged the return line. After I clean out the return line, the engine runs fine again for awhile. My question is . . . Can the governer assembly be replaced without a complete injection pump overhaul? $:(
The pump only has about 500 hrs. on it since the last overhaul.
So far I have been unsuccessful finding replacement parts for this injection pump. Any info is appreciated.
Tom
   / JD 4010 Fuel Injection Pump Issues #2
with only 500 hrs since the rebuild it should still be under warrenty, there is a place up here in canada where i get most on my parts for my ford 5600 and my kubota m8950 dt its a new and used tractor part place and it s called sexsmith used parts the nuber is 1 800 340 1192 but wont be open until tomorrow as this wekend is our labour day holiday i hope this works for ya .don [the bear]
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
JLG 600AJ SKYPOWER TELESCOPIC BOOM LIFT (A60429)
JLG 600AJ SKYPOWER...
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
CFG Industrail MX15RX (A53317)
CFG Industrail...
