jd 3520 snowblower
/ jd 3520 snowblower #1
balzerja
Green Lake,Wi
john deere 3520
Can I put a 72" rear mounted blower on my 3520? A 60" will not cover the rear tire width. Will the tractor have enough power to handle a 72"/
/ jd 3520 snowblower #3
I acquired a 60" single auger rear blower when I upgraded to the Cab model. I have the Rear R3 Turf's in the wide position and don't notice a "coverage" problem. Will a 3520 handle a 72" - of course - BUT - how deep is the snow? How wet is the snow? How fast do you plan to travel? How heavy is the blower? Will you need front ballast / chains? Is your area flat / hilly?
For 98% of the time - in my area - I'm sure my 3320 would handle a 72" blower, at other times, with a large wet drift or clearing the pile left by the rural snow plow in the driveway, I'm sure a 60" could bog down even your 3520.
Without being well versed regarding your local snow conditions and how you plan to use the equipment, I don't think any of us can give a definitive answer.
I have a 500' drive which is flat in central Wi. I'm looking at a 72" from Northern Tool and it says you should have a 40hp tractor. Not running any races ,just want to clear thne snow.. got R4 tires on it which makes it stand 68" wide at the rear.
/ jd 3520 snowblower #5
A 72" blower should fit your machine very well.
/ jd 3520 snowblower #7
I have had a 75 inch Meteor on my 3320 for 4+ years...has handled 3+ ft drifts and 2 ft snow falls with ease.
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
John Deere AH202558 25ft Full Finger Auger (A65640)
John Deere...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
