jd 3520 snowblower
/ jd 3520 snowblower #1
balzerja
Green Lake,Wi
john deere 3520
Can I put a 72" rear mounted blower on my 3520? A 60" will not cover the rear tire width. Will the tractor have enough power to handle a 72"/
/ jd 3520 snowblower #3
I acquired a 60" single auger rear blower when I upgraded to the Cab model. I have the Rear R3 Turf's in the wide position and don't notice a "coverage" problem. Will a 3520 handle a 72" - of course - BUT - how deep is the snow? How wet is the snow? How fast do you plan to travel? How heavy is the blower? Will you need front ballast / chains? Is your area flat / hilly?
For 98% of the time - in my area - I'm sure my 3320 would handle a 72" blower, at other times, with a large wet drift or clearing the pile left by the rural snow plow in the driveway, I'm sure a 60" could bog down even your 3520.
Without being well versed regarding your local snow conditions and how you plan to use the equipment, I don't think any of us can give a definitive answer.
I have a 500' drive which is flat in central Wi. I'm looking at a 72" from Northern Tool and it says you should have a 40hp tractor. Not running any races ,just want to clear thne snow.. got R4 tires on it which makes it stand 68" wide at the rear.
/ jd 3520 snowblower #5
A 72" blower should fit your machine very well.
/ jd 3520 snowblower #7
I have had a 75 inch Meteor on my 3320 for 4+ years...has handled 3+ ft drifts and 2 ft snow falls with ease.
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
Kubota M6950 (A64127)
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
Case International 21' Disc Harrow (A64127)
Case International...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
