jd 3520 snowblower
/ jd 3520 snowblower #1
balzerja
Green Lake,Wi
john deere 3520
Can I put a 72" rear mounted blower on my 3520? A 60" will not cover the rear tire width. Will the tractor have enough power to handle a 72"/
/ jd 3520 snowblower #3
I acquired a 60" single auger rear blower when I upgraded to the Cab model. I have the Rear R3 Turf's in the wide position and don't notice a "coverage" problem. Will a 3520 handle a 72" - of course - BUT - how deep is the snow? How wet is the snow? How fast do you plan to travel? How heavy is the blower? Will you need front ballast / chains? Is your area flat / hilly?
For 98% of the time - in my area - I'm sure my 3320 would handle a 72" blower, at other times, with a large wet drift or clearing the pile left by the rural snow plow in the driveway, I'm sure a 60" could bog down even your 3520.
Without being well versed regarding your local snow conditions and how you plan to use the equipment, I don't think any of us can give a definitive answer.
I have a 500' drive which is flat in central Wi. I'm looking at a 72" from Northern Tool and it says you should have a 40hp tractor. Not running any races ,just want to clear thne snow.. got R4 tires on it which makes it stand 68" wide at the rear.
/ jd 3520 snowblower #5
A 72" blower should fit your machine very well.
/ jd 3520 snowblower #7
I have had a 75 inch Meteor on my 3320 for 4+ years...has handled 3+ ft drifts and 2 ft snow falls with ease.
Hesston 3717 Hay Tetter (A65640)
Hesston 3717 Hay...
2017 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 MACK CXU613...
John Deere Sign (A64127)
John Deere Sign...
2013 KENWORTH T6 SERIES (INOPERABLE) (A65643)
2013 KENWORTH T6...
KMC Hi-Residue Plow (A64127)
KMC Hi-Residue...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
