Backhoe JD 3320 with backhoe
/ JD 3320 with backhoe #1
sunrisefarm
Well I think I've decided to purchase a new JD 3320 (after lengthy deliberation). I want to put a backhoe on it..either the JD375 or
JD485. I was wondering if anyone has either of these setups and could give me some input to help me decide which hoe to get.
/ JD 3320 with backhoe #2
I was thinking about the same thing. I spoke with two dealers and each recommends the 375 even though they admit the 485 fits. One said that the 485 will work okay on the 3520 and 3720 but discouraged it for the lower hp versions of the 3000. I notice that the Woods BH90-X won't even on the 3000 series. I kind of wonder whether the extra power and reach of the 485 matters that much in the real world.
/ JD 3320 with backhoe #3
Makes no sense - 3320, 3520, and 3720 have an implement hydraulic flow rate of 8.6 gpm. Doesn't take more hp to run the hydraulic pump.
/ JD 3320 with backhoe #4
I have a model 448 on my 3320 which works just fine. I could be wrong, but I remember that my choice was between a 447 and 448 and the dealer said the '48 would work and is what people usually put on. Not sure what a 485 is, but the specs are the same as the 448.
/ JD 3320 with backhoe #5
Yeah...I would wonder why your dealer's don't understand that hydraulic capacity is not directly related to motor hp...and if JD says it will work, IT WILL WORK!!
485 is just an updated model.
/ JD 3320 with backhoe #6
gamble77 said:
...485 is just an updated model.
Another mystiyfing model # change. A 448 becomes a 485. The 448 must really have been a 484 so that the 485 can be superceded by a 486. It will probably be superceded by a 648.
/ JD 3320 with backhoe #7
Sunrise can't tell what part of the county you live in but TriGreen in the Southeast has (8) 3520 in stock with a 0% interest for 60 months. You can even pick up the tryed and tested 790 for 0% for 48 months. (5) remaining in stock. This opens up your backhoe options even more.
/ JD 3320 with backhoe #8
Gee, I wish i could have gotten that for the balance on mine, that would have made payment sweet!
/ JD 3320 with backhoe #9
The jump from the 8' to a 9' hoe is a major factor when it comes to leverage. Even though the 3320 may have the hydraulic power to run the 9' hoe, you may find yourself not having the weight to hold the tractor in position on the ground
/ JD 3320 with backhoe #10
Looks to me like the 485 is the version of the 448 which would be cab capatible; otherwise it's the same hoe as the '48.
/ JD 3320 with backhoe #11
The 447 size has enough power to bounce the tractor around as well - so don't let that be the deciding factor.
I have not physically seen a 375 / 485, but as best as I can determine they are essentially the same as the 447 / 448 with a different mounting system that effectively pushes the BH x inches further back, so the BH seat can clear the glass in a cab model. With my 447 when the BH seat is in operational position I have to move the tractor seat about half way forward, otherwise the BH seat interferes with the back of the tractor seat. If there was a cab installed it would not be possible to put the BH seat in operational position. The new models solve that problem.
I suspect the 375 designation relates to 7.5' dig depth and the 485 to 8.5' depth. With either model pushed back x inches there will be a greater lever effect.
Thanks for the input. I think I'm going with the 485. The extra reach is just too appealling. If JD says the hoe fits the 3320 I'm guessing (hoping) it won't hurt the tractor.
/ JD 3320 with backhoe #13
I am not sure on the new models--but when I was looking at 447/448 choices--the 448 fit the next series up (4xxx) so I would be able to transfer it if I ever moved up a frame size--just something else to consider!
2006 HEIL MC407 (A67714)
2006 HEIL MC407...
2025 CATERPILLAR 265 SKID STEER (A65056)
2025 CATERPILLAR...
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
2012 MACK CHU613 (A67714)
2012 MACK CHU613...
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
2003 PETERBILT 330 DAY CAB (A67714)
2003 PETERBILT 330...
