Backhoe JD 3320 w/cab subframe mount for Woods 750 Backhoe?
   / JD 3320 w/cab subframe mount for Woods 750 Backhoe? #1
bennatti
Maine
JD 3320 + cab + 300 CX FEL
I have a Woods 750 Backhoe which I used for years (decades) on my previous tractor....it uses a 3 point hitch system (Woods calls it the Saf-T-Lock system)...apparently ignorance was bliss in that I was never aware of the dangers inherent in a 3 pt mount system. Now that I have my 3320 with cab I would like a subframe mount...but as far as I can tell...none exists. When I search for one for a Woods BH750...the only thing I find is one for the BushHog 750 backhoe. Any suggestions?
I have sent an email directly to Woods....I fear the answer may be...sell the old backhoe and buy a new one.
   / JD 3320 w/cab subframe mount for Woods 750 Backhoe? #3
Post the reply from Woods. I have thought about it for mine, but results are far and few.
Will do...if I get a reply...if not I might try a phone call.
   / JD 3320 w/cab subframe mount for Woods 750 Backhoe? #5
Be very surprised if they make a sub frame mount. Chances are you'll be getting a new backhoe.
   / JD 3320 w/cab subframe mount for Woods 750 Backhoe? #6
You have to other choices , Build a sub frame or buy one from Deere and attach your backhoe to it
Just heard from my dealer who thinks the subframe for the BH 70 will fit....will look into it....doesn't look to me like it will w/o a modifications....but at least its a start.
   / JD 3320 w/cab subframe mount for Woods 750 Backhoe? #8
LOL its all about the modifications. Buy an older tractor and that's all you do , I couldn't find a reasonable priced #7 Backhoe for my 755 so I cut down a New Holland 757 and it looks factory now. Where there's a will there's a way ! Good luck and keep us posted !
Metal Body Holding Sasquatch (A57454)
Metal Body Holding...
4ft 3 Point Hitch Scrape Blade (A57454)
4ft 3 Point Hitch...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2008 Mazda CX9 SUV (A56859)
2008 Mazda CX9 SUV...
