JD 3320 Heater - Resistors
/ JD 3320 Heater - Resistors #1
Lorna1234
Nova Scotia
JD 3320
Could anyone tell me where I could buy .75+.75-216/22 Resistors, or do I need to purchase the entire motor for my heater?
/ JD 3320 Heater - Resistors #2
I was curious if you found the blower motor resistor you were looking for?? My blower motor resistor went bad in my 3720 and Deere only offers it with the entire blower motor for $220. Just curious if I can get just the resistor somewhere? I found it on the website below, but shipping from Poland to USA has an estimated delivery date of December 2016!! Any help would be great!!
Regulator SPAL
/ JD 3320 Heater - Resistors #3
I don't understand the resistor numbers you quoted, resistors are usually color coded for their value and are specified in "ohms".
/ JD 3320 Heater - Resistors #4
Can I ask why you think your resistors are bad as they are usually unlikely to fail.
Plse look at this youtube video if you would benefit from some education on the topic.
https://www.youtube.com/watch?v=Q-i0tytSYIM
This Vapormatic site shows a number of different John Deere resistors.
https://www.vapormatic.com/tractor-parts.ashx?descsearch=blower resistor#part_list
If you are still stuck I would go to an auto wrecking yard. Preferably one of the older ones who will go and look in the junkers for an item.
I think the heater fan resistors are very similar between car and truck makes and tractors.
The resistors work by using up some of the voltage being supplied to the heater fan by converting it into heat which is sucked up by the air circulating in the heating system ducts.
The full speed position bypasses all the resistors so you wont make your existing fan run any slower when it is on high speed.
At the intermediate speeds the resistors are used alone in some settings and perhaps even connected end to end i.e. in series to produce an even slower speed.
The resistors will look like coils of wire that glow red like the element in a toaster. these are not electronic device resistors.
Do not operate or power them unless they are in front of a fan to keep them from over heating.
How many speeds does your current system have? At the wreckers ask them to find resistors from a system which has the same number of fan speeds.
You may have to alter the hole in the tin work to fit the new resistors.
Dave M7040
/ JD 3320 Heater - Resistors #5
These are called "Heater BLOWER Resistor Rheostat's", and can be purchased separately.
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
Iranch High-End Tricycle (A64119)
Iranch High-End...
2019 Chevrolet Express 2500 Cargo Van (A64556)
2019 Chevrolet...
2021 Ford Explorer SUV (A64557)
2021 Ford Explorer...
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
2020 CATERPILLAR 259D3 SKID STEER (A65053)
2020 CATERPILLAR...
