Snow JD 3320 front snow blade
/ JD 3320 front snow blade #1
Muff
I am a new member:) , but have been reading the site for a few months now. I just picked up a 3320, and would like to add a facotry(JD)snow blade.
Does anyone have one? What model? Price? How does it perform?how do you like it? etc... Any help would be great. Thanks in advance.
/ JD 3320 front snow blade #2
Muff, what front blades are available for the 3320? I've had a model 74 mounted on my old JD870 and currently have a model 390 on my 3520 cab tractor. Do you have a loader on your 3320 or plan to get one?
Sincerely, Dirt
/ JD 3320 front snow blade #3
Welcome to TBN MUFF:D
The 74 series or 84 series plows will fit your machine I think. They are built like tanks and do an excellent job of plowing snow and loose materials. The cost will be about $2000.00 or so...You will have to go talk to your dealer to get a firm # though.
Thank for all of your replies. I've seen the 366 on the Deere sight, probably what I'll get. Was curious as to how the 366 holds up, and if people have had good luck with them.
That being said, even though you guys mentioned some older model #'s, have you had good luck with them?
BTW, I do have a loader, but it will not be used for snow.... I have 6 other loaders for stacking and parking lots, this tractor and plow will be used strictly for sidewalks, and miles of them.....
Again, thanks for any and all input.
Great Website.:)
/ JD 3320 front snow blade #7
These plows are heavy and built like tanks. I have an old #380 plow I adapted to my 4110, I think it weighs about 300-400lbs.
Call around to local dealers and see if they have one in stock...It doesn't have to be the #366, it can be a #74,84,380,390...they are all pretty much the same blade except for the mounts.
Kenny,
Was the mod to make the plow fit your 4110 difficult or expensive? I've got the front quick attack (some call front 3 pt quick attach) did you retrofit to a quick attach?
Thanks.
/ JD 3320 front snow blade #9
If you already have the front hitch, than the blade should only be about $1200 or so, The guesstimate I posted above was without the hitch.
I just had to shorten the mid-frame mount and make plates to hook up to where my MMM attaches...no money involved, just time:D
/ JD 3320 front snow blade #10
Kenny post a pic of your plow, you'll never wear that out!
Sorry it looked like I was correcting you...not what I meant...if I could type faster I'd have beaten you to the post. I learned the ole hunt and peck method of typing.
/ JD 3320 front snow blade #11
I have the loader mounted JD one I bought from John (JCMSeven). I use it with my 3320 and 300X. I do not remember the model number right off hand.
Here is a picture:
It works great. Hydraulic angling requires the loader arm oil hard line kit. This kit connects to the 3rd svc at the rear of the tractor.
/ JD 3320 front snow blade #12
Muff, do a search on ebay for Deere blades. You can sometimes pick up a brand new blade for about half the cost from a dealer. I know there are a couple running on auction right now. Just a matter of deciding what mods you will need to do to make it work on your tractor. Sometimes you can even find one close to your location.
Sincerely, Dirt
/ JD 3320 front snow blade #13
Mike, I have the same unit without the hydralic option. Could you post a few pics of the cylinders.I already have the lines to the front to run the angle. I can't find the jd part numbers to order the right cylinders.
Matt T.:D
/ JD 3320 front snow blade #14
Next time I am in the shop I will try and find the model number.
Thanks to all for your input, by the looks and sounds of things, you guys have some sweet set-ups.:D -Muff
/ JD 3320 front snow blade #16
I'd like to pass along a suggestion that was given to me by Killer_B. Sounds like a good idea. Instead of having the "angle" function connected to the rear SCV - use that for the "loader dump" function. Once the dump angle is set it does not have to change too often. Connect the "Blade Angle" function to the mid SCV where the "Dump" function used to be. That way the blade can be raised, lowered and angled using the joystick.
/ JD 3320 front snow blade #17
May have to give that a try. Sounds like a neat idea. Thanks!
/ JD 3320 front snow blade #18
I bought a used 6' Western hydoturn plow for a hundred bucks and made a sub frame that bolts to the front and MMM mounts. What I like about this is when angled the blade is only inches from the front tires. The quick tach on the loader places the blade so far ahead there is not enough weight to keep it in the direction of travel. Also close equates to a tight turning around space.
I also rebuilt the turn rams for $16.00 ( seals ).
Joe,
That is a nice looking custom set up.
FYI to all
I went ahead and ordered the Deere front 3 point hitch for my 3320 today. We have been getting hammered with snow this year in N. Il. so I decided I would go with this set up to give my the option of a blower in the future with no need for mods. Also found out that once you mount the sub-frame, you can leave it in place while running the tractor with the loader on. All that is required is that you remove 3 arms from the sub-frame which is done by simply removing 3 pins. We'll see how it works out.....
/ JD 3320 front snow blade #20
Muff ,
;) I wish I could have caught this post sooner and showed you the "real deal" in hanging a plow on a JD or Kabota tractor. There is alot of ways to do it but without a doubt the finest plow made is the Fisher plows , and most anyone that has tryed them all on a truck will attest to this. There is an adaptor available for hooking right into one on your tractor FEL and you make up two 10ft hoses with 1/4" pipe on one end and JD QDs on the other and plug em into the hydro distibution block and your plowing in about 5 mins. Not trying to ruffle any feathers but it would be hard to compare and Myers or Curtis no matter how it is hung as the blades just dont have the weight or ruggedness of the Fisher plows. I have posted a few pictures on one I recently installed on a JD 3201 with the same 300CX loader! Its and animal with this 7 1/2 quick switch plow and easily shoves 18" of heavy wet snow and will shove it 7 ft into the air! This makes a real sweet setup.
Earle:)
