JD 3203 w/300 loader
/ JD 3203 w/300 loader #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I have found a JD 3203w/300 loader for $12,500 beautiful machine. I googled some reviews and they were terrible so I am hoping for some feed back on the model and price.
/ JD 3203 w/300 loader #2
What are you looking to do with the 3203? What features do you want or need? How many hrs on the machine? Do you have pics?
I have a 3203 which I bought new and, 2.5 yrs and 255hrs later have nothing majorly bad to say about this model. I have used it to move hundreds of bucket loads of manure from my barn/corrals, installed 220 fence posts (with help of a PHD), hauled hundreds of loads of gravel/stones/rocks (landscaping, etc), mowed roadside with 7' sickle bar mower, and not to mention the tons upon tons of snow removal with loader and rear snowblower.
Only thing that would improve the 3203 would be the ability to have additional hydraulics available and a bit more loader strength. Better seat, and additional electrical hookups in the factory fuse block.
Overall I am VERY pleased at what my 3203 has done for me over the 2.5yrs I have had it!!! I am now upgrading to a 3320, 300CX loader, open station w/ front mount blower, as I have some lower back and hip problems and sitting cranked around for 1-2hrs every other day throughout the winter watching the rear mount blower aggrevates things worse. And have now found that more hyd ports will benefit me with what implements I now have.
It all depends on what you are looking for and what you plan to use the tractor for. The 3203 was designed and marketed as an entry level tractor..ie, no frills or added stuff that the average/novice user would not need. Hence the lower price;) $12,500 is not a bad price depending on condition and hrs of it. My trade-in for mine with blower and loader (minus the canopy, bucket hooks, etc) came in at $14,800.
Any questions... feel free to ask!!!
the hydraulics seem to be an issue with these models. I appreciate your feed back.
/ JD 3203 w/300 loader #4
Thanks for the pictures, the hooks on the back of your ROPS for shovels is a great idea.
/ JD 3203 w/300 loader #5
Where are you reading these reviews?
/ JD 3203 w/300 loader #7
/ JD 3203 w/300 loader #8
I have a 3203 and am quite pleased. It is a good basic machine. Does all I ask of it. What are your needs for the machine? $12,500 sounds like a good price. I heard bad stories too of this model, the stock hydraulics are basic and the 300 loader is weak. I purchased the 300CX and I turned up the loaders relieve valve so it will lift a good load (do this at your own risk), I was careful and have had no problems. I also have a Woods bh70X backhoe with a solid frame mount. the hudraulics are run off the tractors pump. Works real good.
/ JD 3203 w/300 loader #9
Need help with my 3203 trottle control lever. Won't hold in rabbit speed on any speed I have to put a piece of wood in the slot to hold it up in a speed...Iwas told to tighten it , but can't get the cover off or dash board area to get behind it to tighten it up...Help Please. John deere fixed this 2 times for us, but I am not taking it in there again for a 3rd time not happy with John Deere Service dept. in sumner, WA....This should not keep happening...Thanks Tractor is about 3 years old...
/ JD 3203 w/300 loader #10
I always thought this was a good little tractor. Was disapointed when it was dropped and replaced with the 3032e and 3038e (though good tractor too) but they where dumbed down even more, the 300 loader I think was a better setup than the 305 with loader mounted joystick would always give me "kubota elbow":laughing:
/ JD 3203 w/300 loader #11
Can you run a Danuser 8300-1 (5-10gpm) hydraulic post hole digger with 9" auger off the front bucket and/or homemade mount for front loader arms?
/ JD 3203 w/300 loader #12
I have a 3203 and have made my own 3rd lines for the front snow plow. And it works great.
I do have a question on the weather brake shown in the picture. What is the FEMCO part number for it?
I could sure use one this year.
Thanks,
Kevin
/ JD 3203 w/300 loader #13
Are you happy with the back hoe? If you don't mind, how much is a woods hoe? Is it hard to remove?
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
2023 Bobcat T86 (A64126)
2023 Bobcat T86...
