JD 318 LOADER
/ JD 318 LOADER #1
dlrfarms
Western,Md.
IH 244,JD4300, 2-JD 4040s,JD2020,JD1020,8N Ford,990 David Brown,3JD318s
My dad has a 318 with a quikway loader on it. The hyd pump is going bad. If I do away with the front pump and plug the loader hoses into the front outlets ? Does the 318 have enough psi and flow to run the loader well?
/ JD 318 LOADER #2
If the pump wasn't needed don't you think it would have been run by the front couplers ? The hydro drive and power steering could use more flow just to operate the basic machine. Rebuild or look for another pump.
/ JD 318 LOADER #3
It may work but it will be really sloow, I don't think you will be happy with it. Take Agent Blue's advice.
Ken
/ JD 318 LOADER
I know that this loader was designed to fit JD tractors without hydraulics also thats why i asked?
/ JD 318 LOADER #5
Not sure on 318 my son had a 400 tha tran off the front couplers. Only had around 1.5 - 2 GPM flow at 700 PSI. Loder worked but it was slow and did not lift real well. Worked OK for mulch but would not lift a bucket of dirt.
/ JD 318 LOADER #6
The best answer is no.
It only has a 1.5 gal hyd tank.
I believe oldnslo is right about the pressure.
A 2 in cyl with 1 in shaft at 700 psi can push with a force of 2,199 lbs straight on, but pushing at any angle will decrease the load potential. Then you have the mechanical relationship, and the weight of the bucket.
The loader pump on my machine is 3 GPM at 3000 and performs well, and only requires about 6 HP. It is also driven from the fan belt on my engine. Cost of the pump is about $120.
http://baileynet.com/index.php?dnfwd=1&page=ProductDetails&line=GPGC&baileyno=250-058
2011 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A63569)
2011 ORTEQ ENERGY...
Kubota RTV 500R-A Utility Vehicle (A64047)
Kubota RTV 500R-A...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
