JD 316 voltage regulator problem
/ JD 316 voltage regulator problem #1
popeyes161
I have a JD 316 with an Onan P218G engine that isn't charging the battery. I have 30 volts AC on the stator wires but onl 1-2 volts DC at the regulator with the wire off. This is a new regulator I just installed any ideas
/ JD 316 voltage regulator problem #2
Welcome to TBN! I moved your thread into the John Deere Owning/Operating section so more users will see it and give you some feedback!
/ JD 316 voltage regulator problem #3
maybe the regulator is sensing no load and reducing the voltage. try with the wires hooked up just make sure the positives and negatives are in the right places. Atleast you didn't make the same mistake I did.
I once changed a stator on a 316 thinking it was bad but turns out the regulator was bad. I was checking the voltage from the stator with my multimeter in DC instead of AC.
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
1762 (A58375)
1762 (A58375)
2009 PETERBILT 367 KILL TRUCK (A63569)
2009 PETERBILT 367...
Ford 3000 Tractor (A64047)
Ford 3000 Tractor...
