JD 3038e Loader won't hold curl
   / JD 3038e Loader won't hold curl #1
omrebel
SOUTH MS
JD 3038e
My 2011 3038 won't hold bucket in curl. If I don't bump it up every 100yds it dumps. I had a 790 that did the same thing and was one of the reasons (although the hydrostat and hp were the main ones) that I traded. Any idea what would cause this problem? Thanks.
   / JD 3038e Loader won't hold curl #2
Disconnect and reconnect the couplers on the four hyd. hoses. See if that helps... may or may not be the problem.
   / JD 3038e Loader won't hold curl #3
Check hydraulic fluid level.
Check for a stuck loader control lever connected to the spool valve.
I'll try disconnecting and reconnecting the hoses and see if that helps. The hydraulic fluid level is not low. Would the curl cylinders need seals after just 4yr and 275hr? I can also check the loader control lever. Thanks for your help, I didn't know where to start..
I haven't found anything that made a difference so far but I did find that it drops much faster when the engine is running. Not running-an inch and a hald in an hour, running-an inch and a half in 15min. I don't know if that means anything or not.
   / JD 3038e Loader won't hold curl #7
deere dude is probably right, need cylinders rebuilt
   / JD 3038e Loader won't hold curl #8
Had to replace mine at about 300 hours or so, and after that it held like a rock, almost.
I guess that'll be next on my list. Thanks again for your help.
   / JD 3038e Loader won't hold curl #10
After reading these posts again I stumbled onto this post that I didn't remember. If the front of the bucket only drops a couple inches in 15 minutes, I would say that would be normal enough. I wouldn't rebuild cylinders if it was that rate. With mine, you could physically see it uncurling. It would uncurl all the way in 1 minute.
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56436)
Greenworks...
1991 Snowco Trailer (A59814)
1991 Snowco...
4 Inch Stargrip (A57454)
4 Inch Stargrip...
LOAD OUT AND SHIPPING (A57454)
LOAD OUT AND...
Mccormick Hammer Mill (A57454)
Mccormick Hammer...
