JD 3010 PTO Problem
/ JD 3010 PTO Problem #1
MAFangusfarm
Edinburg, ND
Had a little problem with my 3010 JD today. I was mowing hay and I broke a sickle section so I stopped the PTO to fix the section. When I got back on the tractor to start again the PTO started but when I got into some heavier hay the PTO stopped and I could hear a winding noise coming from the tractor. I have heard gears in the rear of the tractor behind the stub shaft wont mesh and it can be temporarily solved by putting a penny between the stub shaft and the shifter rod on the inside of the tractor? I would prefer not to split the tractor and anyone with any insight or experience to help fix my power shaft I would sure appreciate it. Thanks again for your help.
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
Unverferth Perfecta 12 (A64126)
Unverferth...
Cushman Hauler 800X (A64127)
Cushman Hauler...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
Wheel Loader Forks (A64126)
Wheel Loader Forks...
