JD 3005 keeps dying
/ JD 3005 keeps dying #1
CharlieM66
john deere 3005
Does anybody know why my 3005 keeps dying while I'm operating. Seems like it doesn't start dying until I have been using awhile and it gets warmed up real good. I simply turn key off, put in neutral, and re-start. It turns over a few times and starts right back off. Could run another 5 minutes or 30 minutes but then it dies again. I've been keeping up with all maintenance but still doing it. I've done everything but take it to the dealer. It's 4 years old and less than 200 hours. Any ideas?
/ JD 3005 keeps dying #2
Welcome to TBN!!
That is an odd one...especially for a 3005!!
When your 3005 cuts out, does it just stop? Or, does it sputter a bit before the engine stalls?
Does it start right back up?
How long has this been going on? Are you using the PTO when this happens?
Initially, I thought you had a fuel problem...water in the fuel (checked the water seperator?) or something (maybe in the fuel tank) that is causing a momentary blockage.
However, neither of those would (I think) occur only after the tractor warms up.
Next, check out your safety switch under the seat (easiest one to get to) to ensure the wires are connected tightly. There's also neutral and PTO safety switches. I don't recall where they're located. If you have the service manual, it has a schematic and test procedure for those switches.
You wrote that you "have done everything but take it to the dealer". What have you tried, so far?
/ JD 3005 keeps dying #3
I recall someone else complaining about this. That problem had to do with a bad ground intermittently cutting out the engine at no specified time.
/ JD 3005 keeps dying #4
It's quite possible the fuel tank cap vent is plugged. Loosen the cap to assure there's airflow into the tank. If the problem goes away replace/repair the cap.
Change fuel filter, if you got some bad fuel it could be blocked and when not running sediment settles to the bottom of the filter allowing it to run until system pressure/flow sucks all the trash back up into the filter surfaces.
/ JD 3005 keeps dying #5
A diesel engine in reasonable mechanical condition needs only fuel and a a starter to start and run. You appear to have that some of the time.
I'm not familiar with all the interlocks on your tractor but check all the switches and all the wiring for the fuel shut off solenoid. A loose wire or connection could be causing your problem. Check the battery ground connection also.
Thiough your symptoms don't appear fuel related, if the electrics check out, look for partial blockage in the fuel system (tank strainer, water separator, etc), or air leak into the fuel line, blocked tank vent,etc . maake sure the fuel delivery lines are all snug . A partial blockage would provide enough fuel flow for a start and perod of times of running. What ambient temperatures are you operating at?
Usually when it starts to die, it just dies without sputtering. Sometimes it will start to die and then just kick back in and keep going. When it does die, it will start right back up. I have to turn over a few times though before it does. We've been in a drought for about a year so havent used a whole lot, but I'm gonna say been happening the last few times I used it. Does it with and without using PTO. Yes, checked water seperator. It starts happening when the engine temperature needle rises just an 1/8 of an inch. Have not checked any safety switches, don't think thats it but will check just in case. Have not really done anything "mechanical" to check it out. Just changed every filter and lubricant it has. I went and talked to mechanic at John Deere and they all say its fuel filter, but I've changed them twice.
I'm going to dig in and check all switches and grounds, and definitely fuel cap. Think this is where problem is.
Thanks for your help fellas. Will report back when problem is fixed.
/ JD 3005 keeps dying #7
Since you wrote you haven't used it much...how old is the fuel? Or, did you put fresh fuel in there?
Diesel fuel is more stable the gasoline, but can develop a bacteriological contaminant.
/ JD 3005 keeps dying #8
There is a bad ground in there, check your ground wires.
/ JD 3005 keeps dying #9
I remember reading a post a couple years ago where someone had a bee in there tank and it caused this same problem. It would run for awhile and the bee would get sucked to the outlet of the tank and then the tractor would quit. Once the engine stopped the bee would float back away from the outlet and it would work until the bee got sucked down again. Not saying this is your problem, but it sure wouldnt hurt to take a good look inside your tank. Good Luck.
/ JD 3005 keeps dying #10
CharlieM66,
just wondering if and what you found with your 3005 stalling problem. Recently had the same problem. I thought it was going to be the ectric shut off solenoid on the pump but no such luck. I had a good look at the switch and wiring for the seat switch and even bypassed to to check but still stalls. It seems to act alot how you explained your problem, no particular reason or time interval and unit restarts.
Just wondering if you found the fix if it was a wiring problem.
thanks
ppbeukema@yahoo.com
/ JD 3005 keeps dying #11
CharlieM66,
I am also interested in your problem. I have a 3032E that also has similar symptoms. It first stalled when box scrapping my gravel road incline. I assumed that it was the inclined that prevented the fuel from reaching the cylinders so the JD dealer mechanic recommended a new fuel filter and fuel pump. It did not fix the issue. The engine dies suddenly. I have to wait a 5 minutes, then turn the key to activate the fuel pump, and turn it 3 or 4 times (sometimes 10 times) and then it begins to sputter, and dies. It seems like at that point, fuel begins to reach the engine, the following crank starts right up, but for only 10 or so seconds, and then it dies again. The third time is the one that is odd, it starts right up and then after 15 or so seconds, the idle drops and blue smoke comes out of the exhaust, than then it dies. The fourth time is when it cranks and stays on for 5 minutes or so, before it dies..
I have put new fuel into it, but did not check for bees or crap that may have fallen INTO the tank...Thanks for the tip Ken!
Thanks,
zenun4dim@gmail.com
/ JD 3005 keeps dying #12
truimage and Ben Nun,
You might want to PM the OP, since the last post was about 15-16 months ago.
/ JD 3005 keeps dying #13
I had this same problem with my 2012 3005 last year during the summer. I was going nuts. I finally started blowing air through the fuel line back up into the tank and after about a month of fooling with this the problem seemed to Disappear. I ran all the fuel out so I could see into the tank, but found nothing.
Now, a summer later, I am starting to have the same problem. I pulled the fuel line and had incredible flow, almost like a garden hose with a high pressure stream. Yesterday while mowing I was still having the problem and loosened the gas cap. I did have a an improved ability to mow, but still had the tractor dying about every 20 minutes.
Last season, I was getting no fuel through the line and thinking that possibly the fuel line had deteriorated and a small piece of rubber was occasionally flipping down and blocking the fuel from getting through the hose line. When I would blow air back up the line, it would fall back up into place, then later as the fuel went through the line, flipped back down and blocked the flow again. I haven't replaced the line, but plan to along with looking at the fuel cap and running fuel back out again to check for debris in the tank again. Seems like the summer months are creating a problem though.
/ JD 3005 keeps dying #14
Hey folks!
I'm a newbie with a 2012 3038e that found this thread only after submitting my own and learning that I titled it identically and I wrote almost exactly what this guy did for symptoms. Did this ever get an answer because I could have inserted my name on this post and called it a day if I'd have known this was out there. I will go check the fuel vent cap thing asap btw.
/ JD 3005 keeps dying #15
I see no replies from the OP on whether he got his problem fixed but did notice he posted this in Jan 2012. Also, not knowing where he lives (his location is not filled in) but if he lives in cold country its possible his fuel was starting to gell up due to cold weather and maybe still using summer fuel. He must have resolved the problem in the almost 5 years since his post.
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
2019 HINO 268 26FT 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 26FT...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
Misc. Pipe Lot 1 1/4", 2", and 3" Poly Pipe (A62679)
Misc. Pipe Lot 1...
