JD 2520 "ticking" noise
   / JD 2520 "ticking" noise #21
Wonder if he ever found out what the problem was, this post was from 2012
   / JD 2520 "ticking" noise #22
Curious also. I had a ticking noise on my 2320. Found out what it was when the fan belt let go. The ticking was a frayed piece hitting some structure. Annoying but a pretty cheap fix. Replaced it with a Gates instead of the original Japanese unit.
   / JD 2520 "ticking" noise #23
well exhaust gaskets didnt fix mine or adjusting the rockers. Dealer doesnt want to help anymore so any ideas would help. The dealer has now told me that its just a characteristic of my engine.
   / JD 2520 "ticking" noise #24
When you say tick, I really hope you don't mean 'clunk'? That's usually a sign that you need to replace a boot/cv/axle, which can be pricy (though if need be, you can grab aftermarket parts somewhere like AmericanCVStore.com and they can help you out a bit on price). Good luck, I hope you figure out / have figured out the cause of the tick!
Update.... Have never been able to find the source of the "tick".....however.... The noise has reduced significantly as time goes on. Dealer has been unable to find anything.
Tractor seems to run fine still.
Sent from my iPad using TractorByNet
2014 Chevrolet Tahoe 4x4 SUV (A55853)
2014 Chevrolet...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
Kubota L3130 (A53317)
Bobcat T590 (A53317)
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
