JD 2520 Snapped Axle
   / JD 2520 Snapped Axle #61
Holy.... Talk about meeting the judges, juries, and executioners all in one thread.... Without seeing it firsthand who the heck knows what happened..
Being both a pilot and mechanical engineer, It is hard to point a finger when you are simply looking at pictures.....
All true...but this is an internet forum, after all...
   / JD 2520 Snapped Axle #62
I'm not a metallurgist (my field is Quality Assurance/Engineering), but I think you're simplifying things a bit too much for that blanket statement. Fatigue strength depends on the alloy and, more importantly, the design.
If there had been a trend in failures of this design and material, you'd have a point...but to the best of my knowledge, there hasn't been a lot of failures (more then likely, we would have read about it on TBN).
BTW, I think most ferrous castings on tractors are cast iron, not cast steel.
Most castings on tractors and other equipment are ductile iron. Not cast iron. Cast iron is far too weak for stressed components. If parts are under high loads, then the parts are forged.
You are correct. Fatigue strength depends on material. Steel has a much higher fatigue strength (general alloy) than aluminum (general alloy).... approximately 2 times.
Obviously something caused the failure. If the casting failed... the part either had a crack (defect) from the factory or operation loading exceeded design specs.
   / JD 2520 Snapped Axle #63
That's what forums are for.... discussion and hypothesizing. So don't take it too seriously. :)
   / JD 2520 Snapped Axle #64
I'll repeat, split your brakes and set your cruise control and try and stop with one brake on damp soil. It will leave a skid mark just like that one. You don't even need to be going very fast to do it. Unless you creep around at idle in low gear all the time on a tractor, this is what happens when a tire locks up. Not abuse.
cant wait to try it. Loved to watch the FIL lockup one side on the 566 fiat and swing around a turn. Never tried it on the 4610.
good input on this one slow:thumbsup:
   / JD 2520 Snapped Axle #65
Hi All , i think the poor chap posted this accident up to see if anyone had any idea of what might have happened....as result a lot of folk have given fair input, and if i were him i'd sift through it all to be better armed with a few reasoned questions to put to JD dealer - IMO thats better than just say "hey it broke."
my friend has one of these machines, rotaryhoe, blade work etc in tough rock country and had no trouble, but on a very bad day when perhaps things line up wrong it can happen. i've seen severe seal damage to 60-80 hp tractors from bale netting, so that could well have momentarily hooked IF... that tyre was jammed from the back linkage, and IF the implement jolted for what ever reason, each event on its own probably would have been handled, but put 2 or 3 events happening just at the one time and bingo - snap. otherwise some casting imperfection could be the case - probably have better idea on that after the axles out.
regardless it was a sad day - i feel for u mate, it would be a dissappointment.
cheers OzG
   / JD 2520 Snapped Axle #66
Hmmm I dont use my cruise and boxblade at the same time. I creep around when using my boxblade so I have enough time to react to the needed changes and settings.
   / JD 2520 Snapped Axle #67
Although there has been a certain amount of judgement passed on the situation by those posting to this thread, I think it has been enlightening.
As an owner of a 2520, I have learned that there are really two 2520's (not counting the one from the 1960's). The 2520 that was made between 2006 and 2008 is different in a number of ways than the ones built from 2009 onward. This was a point of confusion for me when I was using forums such as this one to do research prior to buying mine. Reading postings from people complaining about the small alternator and the problems with lift arm to tire contact made me wonder if I was making the wrong choice of tractor, until I realized that Deere (Yanmar) had changed all that. I later discovered that they also have different engine models between those same years.
This owner's unfortunate experiences seem to make it clear why the lift arm design needed to be changed. If there is too much sway in the 3PH with either a heavy or heavily ground engaging implement attached, then the lift arm can be pulled into contact with the tire so as to stop it from turning. Because of the angles and torque involved, it puts too much stress on the final drive and damages it, eventually leading to failure.
   / JD 2520 Snapped Axle #68
I realize this may not be the place for this, but... What is the difference between the two engines. I have a 2006 model FWIW.
   / JD 2520 Snapped Axle #69
My comment to use cruise is based on owning an HST Kubota, my brake foot is my hst foot so I can't simulate locking up one tire without cruise. If you have a Deere, ignore. My Massey gear drive I would just step on one of the split brakes.
   / JD 2520 Snapped Axle #70
They are similar and both are called 3TNV82A. The older one is a -MJK and the newer one is a -BMJK. I know the newer one has a different oil pump and uses glow plugs instead of an intake heater. I believe that it also has other differences, which may include meeting different emissions standards.
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
2022 BUCKEYE BMH CAR HAULER TRAILER (A52141)
2022 BUCKEYE BMH...
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
1004 (A51572)
1004 (A51572)
(8) TRACTOR WEIGHTS (A51244)
(8) TRACTOR...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
