JD 2320 with MMM
/ JD 2320 with MMM #1
jcdogfish
Louisiana
Mahindra 2516
Is there anything left hanging down after the deck is removed?? I'm looking hard at this tractor and trying to decide on a MMM or finishing mower. Thanks
/ JD 2320 with MMM #2
Does it have the independent lift on it?
I believe when the mower is completely removed there is nothing to hang down(that is how mine is w/o the mower, I have a RFM). Now if you leave the linkage on the tractor it might hang down some but it shouldn't be too bad with it locked up.
/ JD 2320 with MMM #3
With the independent lift kit, the lift arms are still on the tractor, but when locked up they don't hang down enough to be of any concern. I assume it's similar without the independent lift kit, but I never really looked close at one.
/ JD 2320 with MMM #4
Not sure if it is in your money cards, but step up to the 2520 if you can. It has twice the hydraulic power, a better alternator, bigger tires, and a few other things I don't remember.
/ JD 2320 with MMM #5
no the arms move and are out of the way. then move the height dial up locks them up so you can use the 3 point hitch. but if you can get a 2520 there is alot of upgrades that are big if your into proformance. 2 hydraulic pumps. one for steering & the other for the hydraulics. i had a 2320 for a year. but needed more power so i got the 2720 its everything i need. snowblow 52",mow62",loader work,tilling with no bog downs.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
Sitrex 2GL-T Hay Tetter (A65640)
Sitrex 2GL-T Hay...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2010 GMC 3500, Crew Cab, 2WD, Dually (A62679)
2010 GMC 3500...
Bush Hog 18ft. Disc (A65640)
Bush Hog 18ft...
