Mowing JD 2320 Rotary Mower Question
   / JD 2320 Rotary Mower Question #11
RoyJackson said:
For Efreet: BTW, did you mean 2320 or is the 2030 a new Deere not shown on the web site?
Sorry, brain lock. I meant the 2320.
   / JD 2320 Rotary Mower Question #12
UpstateNYMarine said:
Roy,
Your CUT had no problems with the 5'er behind her? Its too late to change my mind now since I already ordered it but just making sure none the less. Also any of you have the iMatch? Do you suggest it and what is a good price on one? Thanks
I can only answer the question about my tractor/cutter.
Nope...no problems at all other then an occasional stall or the engine bogging down.
Actaully, the only advantage of the 790 (with 8 more PTO HP) is when the tractor bogs, the 790 recovers faster.
You can probably change your order...your call, not the dealer's
   / JD 2320 Rotary Mower Question #13
No prob...I have them all the time
   / JD 2320 Rotary Mower Question #14
Efreet: Went with a Speedco. Knew I was going to weld chain boxes to the QH, so adding Green paint wasn't a problem. Regardless of brands, a QH certainly makes life a lot easier. I routinely drop my ballast box to either skid logs or do some blade work--don't need to leave the seat. The Speedco mates to the LX with no mods. It didn't work with an older Brushhog brand without the upper link "H" adapter. Good Luck---al
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
2008 TOYOTA Sienna AWD Van (A56859)
2008 TOYOTA Sienna...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
Kubota M108S (A53317)
2020 Am-Tank 800 Gallon Fuel Tank, S/N 73348, Nominal Capacity 838 Gallon/3172 Liter w/Spill (A59076)
2020 Am-Tank 800...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
