Mowing JD 2320 Rotary Mower Question
   / JD 2320 Rotary Mower Question #11
RoyJackson said:
For Efreet: BTW, did you mean 2320 or is the 2030 a new Deere not shown on the web site?
Sorry, brain lock. I meant the 2320.
   / JD 2320 Rotary Mower Question #12
UpstateNYMarine said:
Roy,
Your CUT had no problems with the 5'er behind her? Its too late to change my mind now since I already ordered it but just making sure none the less. Also any of you have the iMatch? Do you suggest it and what is a good price on one? Thanks
I can only answer the question about my tractor/cutter.
Nope...no problems at all other then an occasional stall or the engine bogging down.
Actaully, the only advantage of the 790 (with 8 more PTO HP) is when the tractor bogs, the 790 recovers faster.
You can probably change your order...your call, not the dealer's
   / JD 2320 Rotary Mower Question #13
No prob...I have them all the time
   / JD 2320 Rotary Mower Question #14
Efreet: Went with a Speedco. Knew I was going to weld chain boxes to the QH, so adding Green paint wasn't a problem. Regardless of brands, a QH certainly makes life a lot easier. I routinely drop my ballast box to either skid logs or do some blade work--don't need to leave the seat. The Speedco mates to the LX with no mods. It didn't work with an older Brushhog brand without the upper link "H" adapter. Good Luck---al
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
2012 Ford F-550 Crew Cab SWAT Transport Truck (A55852)
2012 Ford F-550...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
John Deere 4820 Forklift (A57453)
John Deere 4820...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
KEENCO MIDDLE BUSTER PLOW (A57192)
KEENCO MIDDLE...
