JD 2305
   / JD 2305 #1
Wvanatti
John Deere 2305 (2010)
Gents,
I have a 2010 " 2305". I was mowing with it this morning when it suddenly died. The fuel gage dropped to zero. The tank is 3/4 full. I tried starting it and figured out it will stay running as long as I hold the key switch to start. I was able to drive it back to garage that way. Any ideas where a fuse would be blown and where to look ? Thanks in advance for imput.
   / JD 2305
Disregard, it was the fuse by the air breather (15a)
   / JD 2305 #3
Good to hear you found the problem.
Hope the starter is ok after making that trip back to the garage.
   / JD 2305
Completely my fault ! I had hooked up a trailer last fall and tied into the turn signals with a pigtail, the wire was pinched with the 3 point hitch causing a 20 a fuse to blow. For future reference for anyone ... The motor started back up but only ran when I held the key to on. I was able to let off the key switch gently till the starter quite turning. ( sound ). And drive it. To garage shade. Having my girl not run was a hopeless feeling. Whew - got lucky
   / JD 2305
All is right with the world :). For now....
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2021 John Deere S780 Combine (A50657)
2021 John Deere...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2005 STERLING LT8500 SERIES MIXER TRUCK (A50854)
2005 STERLING...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
