JD 2305 PTO Problem - Need HELP
/ JD 2305 PTO Problem - Need HELP #1
mattmayo
I was bushogging with my 2305 (24hp) and hit a small pine limb (it did not choke out the tractor and it was a small limb). I began to hear a knocking so I shut the tractor down thinking something was caught in the mower. I couldnt see anything wrong so I fired it back up and mowed another 5 minutes or so and the noise persisted.
Brought the tractor back to the barn and noticed that the PTO spline coming out of the tractor appeared loose and a small bit of hydraulic fluid was leaking around it. If you grab it with your hand, you can move it from side to side.
I have read posts about the PTO shaft being too long, however I have used this mower for 3 years and have had no problems at all. I have hit bigger things (by accident) with no issue so this was a surpise!
Have I really messed the back end of the tractor up or is it simply a bearing or other small repair?? Can you shear a PTO spline?? Any help/opinions would be greatly appreciated!! I am not a mechanic so I hope I haven't caused a big $$ problem.
/ JD 2305 PTO Problem - Need HELP #2
/ JD 2305 PTO Problem - Need HELP #3
I think it's like a 8000 dollar repair unfortunately.
Are you mechanically inclined? Good relations with JD dealer? Wonder if JD would offer assistance?
My dad and I can make minor type repairs but a major rear end rebuild would be above our heads
/ JD 2305 PTO Problem - Need HELP #7
you should post this thread in john deere owning/operating section. You will get a lot more replies and suggestions there. Maybe it isn't the major pto failure. who knows
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
Alligator Statue (A64557)
Alligator Statue...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
John Deere 2840 Tractor (A64047)
John Deere 2840...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
