JD 2305 PTO Problem - Need HELP
/ JD 2305 PTO Problem - Need HELP #1
mattmayo
I was bushogging with my 2305 (24hp) and hit a small pine limb (it did not choke out the tractor and it was a small limb). I began to hear a knocking so I shut the tractor down thinking something was caught in the mower. I couldnt see anything wrong so I fired it back up and mowed another 5 minutes or so and the noise persisted.
Brought the tractor back to the barn and noticed that the PTO spline coming out of the tractor appeared loose and a small bit of hydraulic fluid was leaking around it. If you grab it with your hand, you can move it from side to side.
I have read posts about the PTO shaft being too long, however I have used this mower for 3 years and have had no problems at all. I have hit bigger things (by accident) with no issue so this was a surpise!
Have I really messed the back end of the tractor up or is it simply a bearing or other small repair?? Can you shear a PTO spline?? Any help/opinions would be greatly appreciated!! I am not a mechanic so I hope I haven't caused a big $$ problem.
/ JD 2305 PTO Problem - Need HELP #2
/ JD 2305 PTO Problem - Need HELP #3
I think it's like a 8000 dollar repair unfortunately.
Are you mechanically inclined? Good relations with JD dealer? Wonder if JD would offer assistance?
My dad and I can make minor type repairs but a major rear end rebuild would be above our heads
/ JD 2305 PTO Problem - Need HELP #7
you should post this thread in john deere owning/operating section. You will get a lot more replies and suggestions there. Maybe it isn't the major pto failure. who knows
2003 Freightliner FS65 Converted School Bus (A64194)
2003 Freightliner...
2025 Wolverine PT-16-02C Class 2 Three Point Hitch Skid Steer Attachment (A64553)
2025 Wolverine...
2022 EZ-GO ELITE...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
2R ROTARY HOE, 3PT (A64278)
2R ROTARY HOE, 3PT...
Wagon Wheel Chair (A64557)
Wagon Wheel Chair...
