JD 2305 MMM
/ JD 2305 MMM #1
raykos
Central Pa.
JD2305
Hello all,
Does anyone have the mid mount 54" mower with the hydraulic lift included with their 2305? If so, have you been having any problems?
Thanks,
raykos
/ JD 2305 MMM #2
I have the 54MMM with hydraulic lift and have had no problems if you discount the fact the hydraulic lift bleeds off very quickly. There are several posts alluding to this phenomenon on the 2305.
/ JD 2305 MMM #3
My 54" deck cuts just fine and I haven't seen a bit of bleed off. I've left the ballast box on the 3pth, raised, for more than an hour with the machine turned off and still it didn't bleed down.
Raykos, what's the problem you're seeing?
/ JD 2305 MMM
Thanks for the responses. Don't know if this is relevant to our MMM, but at the John Deere site->Residential->Services&Support->AnswerCenter->page 3->question 44, John Deere says this "settling to the ground", may be normal. However, the problem I'm wondering about is the routing of the hydraulic hose; if I don't tie mine up to the deck, it will fall and get caught between the frame and rear tire.
Since I'm a newbie to this forum, I've tried the "Search Forums For" box at the top of the page, but I can't seem to find any other posts related to the 2305 and the MMM, any suggestions on how to do this?
Thanks,
raykos
/ JD 2305 MMM #5
Can you post a picture of what you're talking about?
/ JD 2305 MMM #6
Thanks,
raykos
There is supposed to be a hose clamp,bolt and nut holding it up on the right side before the SCV. Part numbers are; R46414 - 19M7867 - 14M7298
/ JD 2305 MMM
Thanks for the info, bigtiller. Today is Sunday, so tomorrow I will be talking to my dealer about your response and part numbers.
raykos
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
1143 (A63745)
1143 (A63745)
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
KELDERMAN KRC 111D HAY RAKE (A64280)
KELDERMAN KRC 111D...
RING 3 STARTS HERE @ 9:30 AM (A64281)
RING 3 STARTS HERE...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
