JD 2240
/ JD 2240 #1
willy44
MI
John Deere 2240
Hello everyone, I have a John deere 2240 and I was looking around while I was working on it and noticed that there is some kind of sensor in the intake pipe right above the filter box. Now the strange thing to me is that the wire from this sensor goes to the sender pump in the gas tank :confused: I dont have a manual for the tractor but could anybody tell me what it could possibly be.
Thanks
/ JD 2240 #2
Can you post a pic of the sensor and its location?
"filter box" would that be the air filter? And the "intake pipe", be the air intake?
/ JD 2240 #3
Are you referring to the air filter restriction sensor(part key 13)????????????
/ JD 2240
yes TX Jim thanks, I couldn't find any diagrams that had that sensor in it.
/ JD 2240 #5
The wire should go to the instrument panel.. I'd think, rather than the fuel tank pump.
/ JD 2240
The wire does go to the panel, my mistake the harness splits right behind the hydraulic pressure tank where I didnt notice it
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
