JD 2240 Info
/ JD 2240 Info #1
Jethro
Eastern NC
Kubota B1550, several Exmark ZTRs, Walker GHS and a 1967 Craftsman Surburban
I am thinking about buying a JD 2240. The engine has been rebuilt and the entire tractor painted. I can find very little information on this model. The SN is 214382 L, code 224SA. I know that it was made in Mannhiem, Germany. The seller tells me it wade built in 1986, but another source tells me that model was only made until 1982. Does anyone know when this may have been made? How much does it weigh? What is a fair price? The rear tires need to be replaced, all four work lights need replacing and the draw bar and bracket are missing.
/ JD 2240 Info #2
This should give you some good data. JD 2240
Hope it helps you.
murph
/ JD 2240 Info
Thanks very much. That is helpful.
/ JD 2240 Info #4
That is the same as the JD 1640 sold up here. first off the pto hp should be 50.9,not 59.9 as the site says. From what I can find your serial number puts the tractor as a 1976.
/ JD 2240 Info #5
That's not a bad utility tractor. Around 50 some pto hp. I believe your friend was right. They only made those until 1982. The first year they made them was in 1976. Around here one would go for between 4 and 7k. If it was recently overhauled and had a new paint job but needed tires, draw bar, and lights a fair price would probably be $5-6k.
/ JD 2240 Info #6
Those old ones seem to run forever. One thing I like is how the range and gear shift are right in front of you.
/ JD 2240 Info
Yup...you were right. It was released in 1976. I have since decided against this tractor. I really feel like I should get a 4wd if I plan to install a loader. By the time I spent the money installing a loader on this one, the whole thing looked like a mediocre deal at best.
2009 FORD F-750 SUPER DUTY (A67714)
2009 FORD F-750...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2004 Johnson 70hp 4-stroke Outboard Boat Motor (A66738)
2004 Johnson 70hp...
KOMATSU D51PXI-24 CRAWLER DOZER (A65053)
KOMATSU D51PXI-24...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
1997 HUBBLER BROS. LOGGING TRAILER (A67714)
1997 HUBBLER BROS...
