JD 2210 electrical issue! Please help!
/ JD 2210 electrical issue! Please help! #1
04Derre
2004 JD 2210
Well guys, I've done all I know to do with my tractor! Problem is it won't start, I thought the battery went south on me, but it's fine! How it began was I went to mow the grass and it wouldnt start, so I jumped it with my truck and it fired right up, so ok I continued to mow my grass, had to get off to pick up a few things, so I shut my PTO off, when I got back on it I pulled the PTO switch and nothin, I pulled it back in the garage, tried it again and it just died? Now it won't do anything, I've had the starter checked, the alternator? Now I was thinkin it's the rectifier, I did a few test on the rectifier, I have 12.63V at the hot from the rectifier and as soon as u turn the key to start it, the voltage disapears? I haven't checked voltage from the alternator cause it won't start? I've also checked all the grounds ad battery cables to! Your help will be greatly appreciated!!
/ JD 2210 electrical issue! Please help! #2
The PTO switch should be IN when starting your tractor, you may want to double check this. Also make sure that the transmission is in neutral. Just a couple of easy things to check. Are you sure that the battery is fine, have you checked it under a load, if it is the original it maybe time to replace it.
Good luck,
Ken
I haven't checked anything under a load cause I can't get it started lol, I've also got a relay chattering now to, I'm thinkin that might be cause of a low voltage issue?
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
3268 (A63117)
3268 (A63117)
2004 Sterling Ambulance Truck, VIN # 2FZACFCS24AM53402 (A65563)
2004 Sterling...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
