JD 2020 Shifting Problem
/ JD 2020 Shifting Problem #1
Anonymous Poster
Epic Contributor
I have a JD 2020. When switching from Park or Neutral into any gear, many times it will grind the gears. The clutch is pushed in all the way. It's kind of like it takes too long for the gears to stop turning or that the clutch does not quite disengage the trans. If I hold the clutch in for maybe 10 seconds, it might shift fine. Is there something that needs adjusted or is this a bigger problem?
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
Sakai SV505 (A60462)
1992 Rammax Trench roller and Extra Set of Drums (A62613)
1992 Rammax Trench...
(6) 250 Gallon Chemical Totes (A64127)
(6) 250 Gallon...
