JD 2020 2030 Alternator Light?
   / JD 2020 2030 Alternator Light? #11
bodin1968
Are you aware you can view 2020 parts catalog for free at JDparts.com plus if you register with a JD dealer you can check price plus dealer availability of part?
Parts key 1 AT44165 Wiring Lead - LEAD, LIGHT ADD 17.76 USD
   / JD 2020 2030 Alternator Light? #12
Check your brushes in alt. Most of these old tractors are still running the original alternator. Just remove to 2 1/4" screws where wire plugs in and the brushes come out . Replace or brighten them up for temp fix.
thanks for the info.....
   / JD 2020 2030 Alternator Light? #14
You can't use an LED for the alternator/battery light. It has to be able to light from current flow from either direction. An LED only lights from a one way current flow.
thanks for the replies.
noticed my new battery was not recharging. (recently new wires were run from alt to solenoid and battery etc)... having the deere shop replace the pto seal and also check the alternator (which is an original john deere). gonna make sure the alt is fine first then replace that new LED alt light.
Zebra: i have the part# for the replacement jd alt light thanks to TxJim... my dealer doesn't have the light. what light would u recommend i use for the alt light that i may pick up locally or easily order online? tx
   / JD 2020 2030 Alternator Light? #16
Any auto parts store should have it. Ask for 1895r the "r" on the end is for a red, but it does not have to be red to work. So if they have 1895 that is clear it will work.
For online, just "google" 1895r and you should be able to find many sellers.
If the alternator tests OK, it's either a wiring problem (including wrong bulb) or it could also be the voltage regulator.
   / JD 2020 2030 Alternator Light? #17
bodin1968
Voltage regulator is under dash IIRC not easily accessed.
yes, with the recent re-wiring job i know right where the VR is.. how do u tell if the VR is bad?
i removed the left side panel near the battery and that area was easy to access. thanks
Deere shop says alternator was fine.
on the voltage meter the battery registered 13.03 off, 13.65 at idle and 14.13 with higher rpms. so i'm getting juice back to the battery.
AND when i upped the rpms the new jewel LED alternator light actually shut off. i did order the replacement JD alt light but guess now it's not needed...
thanks for the help.. and TXJIM yes i had that clutch disc replaced on the MX6 and that hopefully was the ticket to resolve slipping on the cutter (other thread)
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
Portable Restroom (A54865)
Portable Restroom...
404 (A52706)
404 (A52706)
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
Freighliner Tender Truck (A56435)
Freighliner Tender...
