jd 2010 locked rear wheel in cold temps
   / jd 2010 locked rear wheel in cold temps
It took almost a gallon of 80w gear oil. Oil in the right side is good quality. I appreciate all the help.
   / jd 2010 locked rear wheel in cold temps #12
I will check mine too! Thanks also for the follow up on what happened. I looked in my manual and it says nothing about separate reservoirs....
   / jd 2010 locked rear wheel in cold temps #13
That's because the tractors you have listed in your profile don't have separate oil reservoirs
   / jd 2010 locked rear wheel in cold temps #14
I have changed the oil twice in it and there is still water in the hydraulic oil - do you have a suggestion on how to flush the hydraulic system?
19010 (A48082)
19010 (A48082)
2016 FREIGHTLINER 2500 SPRINTER VAN (A51222)
2016 FREIGHTLINER...
2024 Iron Bull 20ft T/A Equipment Trailer (A49461)
2024 Iron Bull...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
1990 Ingersoll...
1275 (A50490)
1275 (A50490)
