jd 2010 locked rear wheel in cold temps
   / jd 2010 locked rear wheel in cold temps
It took almost a gallon of 80w gear oil. Oil in the right side is good quality. I appreciate all the help.
   / jd 2010 locked rear wheel in cold temps #12
I will check mine too! Thanks also for the follow up on what happened. I looked in my manual and it says nothing about separate reservoirs....
   / jd 2010 locked rear wheel in cold temps #13
That's because the tractors you have listed in your profile don't have separate oil reservoirs
   / jd 2010 locked rear wheel in cold temps #14
I have changed the oil twice in it and there is still water in the hydraulic oil - do you have a suggestion on how to flush the hydraulic system?
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Unused 2025 CFG QK20R Mini Excavator (A49461)
Unused 2025 CFG...
2012 International Semi Truck (A50323)
2012 International...
GAS BUSTER FOR FLARE SYSTEM (A50854)
GAS BUSTER FOR...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A49461)
2017 Ford F-350...
