jd 2010 locked rear wheel in cold temps
   / jd 2010 locked rear wheel in cold temps
It took almost a gallon of 80w gear oil. Oil in the right side is good quality. I appreciate all the help.
   / jd 2010 locked rear wheel in cold temps #12
I will check mine too! Thanks also for the follow up on what happened. I looked in my manual and it says nothing about separate reservoirs....
   / jd 2010 locked rear wheel in cold temps #13
That's because the tractors you have listed in your profile don't have separate oil reservoirs
   / jd 2010 locked rear wheel in cold temps #14
I have changed the oil twice in it and there is still water in the hydraulic oil - do you have a suggestion on how to flush the hydraulic system?
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
TRUCKING INFO (A50774)
