dieselfuelonly
Hey ya'll...
Having some trouble with my JD 175. It has a new starter on it, its been working great for the past couple weeks. Today I tried to start it up and... nothing.
Its not turning over at all. I don't get a click or a stutter or anything... the only "click" seems to be coming from the front of the engine near the carb... not sure what that is though.
I started by checking all the connections that I can see - everything seemed good. Battery voltage is good. I checked the under-seat saftey switch and its working fine (previous owner jumpered it so it doesn't even function, but I checked the continuity and its fine).
So that leads me to believe that its the safety switch that is linked to the brake pedal that requires it to be pushed down to crank.
The problem is, I can't find it. Pulled the deck off and looked underneath and couldn't find it.
Any advise on locating this switch and/or other reason's why my JD wouldn't crank would be greatly appreciated!
Thanks,
Dennis
Thanks,
Dennis
