JD 175 Farm Loader
/ JD 175 Farm Loader #1
JoshB
Spartanburg
JD 2155
I have a 175 loader on my 2155. I bent a rigid hydraulic line yesterday while moving some debris around, which resulted in a hole and a nasty leak. Item #13 seems to be obsolete.
Does anyone know of an alternate PN to AW22254 (other than AW26073)? I might just have to have a line manufactured but I figured it's worth asking.
Thanks!
- Josh
/ JD 175 Farm Loader #2
Picture I have is a bit different but same part #. Looks to be obsolete like you said. I'll check one more source for you and see if we get an answer.
Here is a picture of the line that is damaged.
It is the middle line (behind the one in front) which got bent and twisted by a branch on the right (left on tractor). The twist made a hole under the hose wrap.
/ JD 175 Farm Loader #8
Yea it's obsolete unfortunately. It will be fine if you get a regular hose made for you. Don't need to go back with hard line.
Ok great. That was going to be my next question. I'll just find a flex line and replace it with that.
Thanks for chiming in!
Would your software be able to tell you what the thread size is on the fitting (#17 on the diagram)?
The flex line will probably come with male/male ends. I'll probably have to pickup some unions to make it all work. Maybe remove the fitting from the regulator (#19) and flex hose straight into that, but then will still need a union to connect to the other flex hose (#16).
Would those be 3/4" fittings?
/ JD 175 Farm Loader #12
I'll check once I get back in. I'm testing a tractor right now. Ill get back to you in a second buddy
/ JD 175 Farm Loader #14
Josh
Have you considered welding or brazing your old line? Back when I was employed by a JD dealer I've seen many hyd lines repaired by brazing.
The people I bought it from painted green over everything. Under the paint is a good bit of rust. That line is pretty used up. But thank you for the suggestion!
/ JD 175 Farm Loader #16
Are these the spec's you need?
2006 Volvo VNM T/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM T/A...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67737)
2012 INTERNATIONAL...
2018 MACK LR GARBAGE TRUCK (A66091)
2018 MACK LR...
2025 Ripper Mini Excavator Attachment (A66734)
2025 Ripper Mini...
LEEBOY 8515B PAVER (A67714)
LEEBOY 8515B PAVER...
