JD 170 deck
/ JD 170 deck #1
dodge85rc
MN
What is the biggest deck that will interchange on my jd 170? It currently has a 38", that has nothing wrong with it, but I have to keep up with 6 acres of grass everyweek and don't have the money for a bigger mower so thought I would check to see if there was a bigger one I could swap under easily. I know a lot of the parts from this "100" series of mowers interchange easily.
/ JD 170 deck #2
I believe the 170 was only offered with a 38" deck. The 180 had, 38, 46, and 48" however they mada a longer prodction run and there are some s/n differences on these units. Unless you are handy and can modify deck mounts, replace possbly a pulley or 2 with different sizes and track down what will then be the proper belt I would say go for it. Otherwise I would say you have the wrong machine I would try to trade and/or sell and upgrade to a larger machine. The 170 was not an over powered unit and may struggle with a larger deck.
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
2013 Ford Transit Connect Cargo Van (A61573)
2013 Ford Transit...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2019 CATERPILLAR 259D SKID STEER (A64279)
2019 CATERPILLAR...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
