JD 170 deck
/ JD 170 deck #1
dodge85rc
Bronze Member
MN
What is the biggest deck that will interchange on my jd 170? It currently has a 38", that has nothing wrong with it, but I have to keep up with 6 acres of grass everyweek and don't have the money for a bigger mower so thought I would check to see if there was a bigger one I could swap under easily. I know a lot of the parts from this "100" series of mowers interchange easily.
/ JD 170 deck #2
I believe the 170 was only offered with a 38" deck. The 180 had, 38, 46, and 48" however they mada a longer prodction run and there are some s/n differences on these units. Unless you are handy and can modify deck mounts, replace possbly a pulley or 2 with different sizes and track down what will then be the proper belt I would say go for it. Otherwise I would say you have the wrong machine I would try to trade and/or sell and upgrade to a larger machine. The 170 was not an over powered unit and may struggle with a larger deck.
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 Kivel 42in...
1998 MP CUSTOMS PRESSURE WASHER TRAILER (A67714)
1998 MP CUSTOMS...
2000 PETERBILT 379(INOPERABLE) (A67714)
2000 PETERBILT...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2019 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2019 CATERPILLAR...
