JD 1550 air filter
/ JD 1550 air filter #1
Ronster
CT
John Deere 2520, John Deere X739, Kubota U27-4, Kubota RTV 500
I started this thread in the general forum, should have put it here. Does anyone know if the air filter location ( under the seat ) on the 1500 series JD front mount mowers gets dirty and needs replacement sooner than the older 1400 series with the air filter located above the engine? Is this new location under the seat a pain to change?
Thanks
/ JD 1550 air filter #2
Yes it is. The manual shows the restriction indicator, but not a clear pic of the air filter, and what is near it, possibly blocking easy access. . I have not found a 1550 on a dealers lot, so I am reluctant to drop big dollars into a machine that I haven't seen in action. A sales rep form Grasshopper let me drive a 900D front mount mower at my home. It seemed to be a nice unit, but I would still rather have a 4WD and a steering wheel. Still cutting grass with my JD2520 and a Woods RM660 mower. I hope the owner of a 1550 chimes in soon.
/ JD 1550 air filter #4
The air filter on the 1570 is under the seat. The air intake is on the side located under a removable panel. I am just getting started using the machine but it does not appear the filter will need servicing more often than a typical mower.
I've only serviced the filter once. It is a tight fit. The bottom latch is not visible so you have to feel it into place.
dsb
2020 CATERPILLAR 279D3 SKID STEER (A60429)
2020 CATERPILLAR...
2024 CATERPILLAR 305CR EXCAVATOR (A60429)
2024 CATERPILLAR...
John Deere Z997R (A60462)
John Deere Z997R...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
Bradco 6HFC Hydraulic Trencher Skid Steer Attachment (A59228)
Bradco 6HFC...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
