JD 145 Won't start - Electrical issue
   / JD 145 Won't start - Electrical issue #1
Attono
I have a JD 145, purchased from a Deere dealer about 7 years ago new. It has given me problems for about the last 5 years, where every year I'd have to replace the battery. If the tractor is run for several short periods, it just won't turn over, like the battery is getting drained down and not charging. Over the last several weeks, I have been able to hook up an external battery and jump it and it will start. Runs fine when it gets going. Now it is at the point where when I turn the key, it sounds like the starter solenoid is engaging, but it doesn't turn over. I pulled the fuse and checked it and it was good, plugged it back in and then tried a few times and got it to start.
I hooked up a charger and it said the battery was greater than 80% and then after about 5 minutes, said it was fully charged. Yet, when I try to start it, it won't turn over and I even get some sparking. I'm thinking the starter. What do you guys think?
I get the load test, but what would valve lash have to do with getting the thing to turn over? You can push the thing around by hand, so I don't think it's bound.
   / JD 145 Won't start - Electrical issue #4
There is a correlation between valve lash and compression relief for cranking purposes on briggs engines with OHV ( overhead valve ) engines.
Not sure how to check the lash on this engine. I'm not much of a small motor guy. Any guidance?
   / JD 145 Won't start - Electrical issue #6
   / JD 145 Won't start - Electrical issue #7
This fellow seems to understand valve adjustment when I see him turn the screw rather than the nut to set the lash. But you better tighten the jamb nut back as tight as it was from the factory or that little vibrating briggs will have those valves all out of whack in a heart beat.
https://www.youtube.com/watch?v=hGkn0jR9RJM
Awesome, thanks guys! I'll let you know how it turns out.
   / JD 145 Won't start - Electrical issue #9
Yes, we would appreciate a reply.
I should have mentioned that those items aren't the only things that can be wrong with these little fellers but that's where I would start for the cost of nearly $0.00.
Anybody happen to have a Repair Manual P/N 273521?
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2018 Mitsubishi Eclipse Cross SUV (A53117)
2018 Mitsubishi...
Chevrolet Tahoe SUV (A52377)
Chevrolet Tahoe...
Honda Pressure Washer (A53117)
Honda Pressure...
