JD 145 Won't start - Electrical issue
/ JD 145 Won't start - Electrical issue #1
Attono
I have a JD 145, purchased from a Deere dealer about 7 years ago new. It has given me problems for about the last 5 years, where every year I'd have to replace the battery. If the tractor is run for several short periods, it just won't turn over, like the battery is getting drained down and not charging. Over the last several weeks, I have been able to hook up an external battery and jump it and it will start. Runs fine when it gets going. Now it is at the point where when I turn the key, it sounds like the starter solenoid is engaging, but it doesn't turn over. I pulled the fuse and checked it and it was good, plugged it back in and then tried a few times and got it to start.
I hooked up a charger and it said the battery was greater than 80% and then after about 5 minutes, said it was fully charged. Yet, when I try to start it, it won't turn over and I even get some sparking. I'm thinking the starter. What do you guys think?
I get the load test, but what would valve lash have to do with getting the thing to turn over? You can push the thing around by hand, so I don't think it's bound.
/ JD 145 Won't start - Electrical issue #4
There is a correlation between valve lash and compression relief for cranking purposes on briggs engines with OHV ( overhead valve ) engines.
Not sure how to check the lash on this engine. I'm not much of a small motor guy. Any guidance?
/ JD 145 Won't start - Electrical issue #6
/ JD 145 Won't start - Electrical issue #7
This fellow seems to understand valve adjustment when I see him turn the screw rather than the nut to set the lash. But you better tighten the jamb nut back as tight as it was from the factory or that little vibrating briggs will have those valves all out of whack in a heart beat.
https://www.youtube.com/watch?v=hGkn0jR9RJM
Awesome, thanks guys! I'll let you know how it turns out.
/ JD 145 Won't start - Electrical issue #9
Yes, we would appreciate a reply.
I should have mentioned that those items aren't the only things that can be wrong with these little fellers but that's where I would start for the cost of nearly $0.00.
Anybody happen to have a Repair Manual P/N 273521?
Alright, so I adjusted the lash and it didn't help. It's definitely an electrical problem. I can rotate the engine by hand, but when I turn the key now, I am not even getting the solenoid to go. Lights won't even come on. Guess I'll drag it to the dealer...
Thanks for the help, learned something new.
/ JD 145 Won't start - Electrical issue #12
You can fix this. If the solenoid does not click, is voltage being applied to its coil? If so and no click and no contact thru it, replace solenoid. The solenoid often is damaged from the extreme loads placed on the starter motor from the valves being out of adjustment..The extreme currents fry the solenoid. If there is not voltage on the solenoid coil, check the key switch/fuse. You can fix this. I am assuming you have a volt/ohm meter and know how to use it.
Turned out that some corrosion had crept into the battery cables and was causing high impedance. That coupled with the valve lash problem was the culprit. Some new battery cables and valve adjustment by the pro's and I am back in business.
/ JD 145 Won't start - Electrical issue #14
Glad you got it going, now you will know what to look for next time and can help others.:thumbsup:
2016 Chevrolet Tahoe SUV (A64194)
2016 Chevrolet...
2012 Allmand Nite-Lite Pro II 8KW Towable Light Tower (A64194)
2012 Allmand...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
SARLO (A64557)
SARLO (A64557)
2007 Polaris Ranger XP (A65579)
2007 Polaris...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
