JD 1050
/ JD 1050 #1
banjobj
Southern York County, ME
TC 21D
Does anyone know the Horsepower of the JD 1050? Was it a model that was reliable? Were they produced in large numbers?
/ JD 1050 #2
Check out <A target="_blank" HREF=http://www.machinerylink.com> Machinery Link.</A> They'll give you some good information on HP (in the low or mid thirties, I think), weight (~ 3500#, as I recall), etc., as well as some pricing info and even how to determine the model year of the particular 1050 you're considering. As to the reliability, I've heard them described as "bulletproof" by people who own then and by people who work on Deere products. I looked very seriously at those when I was shopping. I think they're a fine machine. /w3tcompact/icons/smile.gif
/ JD 1050 #3
Nebraska test #1327 rates it at 33.4 HP. 3 cyl turbodiesel.
"Bulletproof" is a good description from everyone I've talked with that has one.
/ JD 1050
Gary and pfoxy, Thanks for the info. My Cousins husband has one and cosmetically it sure looks rough, they have had it 10 or 12 years. They don't have any manuals on it though. Their 1050 has held up well and I wondered how others had been ? /w3tcompact/icons/smile.gif
/ JD 1050 #5
650 through 1250 are great machines.............
/ JD 1050 #6
I just took our 1050 at work out today. It doesn't get used much these days, only to pull a dump trailer, but still started right up and was able to haul a large load of heavy wet sand just fine. Its got over 2900 hours on it, and looks to have had a very rough life, much like some of our other tractors.
/ JD 1050 #7
I think you can still get the manuals from John Deere. There is a phone number you can call (I don't know where I put it) or your dealer can order it for you. Either way it arrives on your door step a couple of days later. They are a little expensive but well worth it the first time you need it.
Chris
SKID STEER MOUNTING PLATE (A60432)
SKID STEER...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
CAT 930M (A58214)
CAT 930M (A58214)
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
