JD 1050 hyd remote
/ JD 1050 hyd remote #1
qstott
Elm City, NC
'65 110 JD, 445 JD, 4720CabJD
Can someone explain the functions of the rear remote on a 1050 to me? There are two levers. The outer lever moves easily and I use it for my hyd top link. The inner lever is where I have a question. It seems to remain in position when I push it forward or reward. It's very stiff when moving. It may stay in the position you put it in. I was looking at a northern tool log splitter and was wondering if the inner lever could be used to control the circuit to the splitter. I don't have power steering or any other hyd circuits on the tractor. It should be simple, but not to me :)
/ JD 1050 hyd remote #2
Does your 1050 have the auto draft sensing feature for control of the 3pt rockshaft arms?
The 1070 has that feature.
AKfish
Yep, it's controlled by a flat u-shaped spring where the top link attaches. The top hole is not draft sensing, but the bottom holes is. (The best I remember)
2020 CATERPILLAR 299D3 SKID STEER (A64279)
2020 CATERPILLAR...
UNUSED ATSPOWER PLASMA CUTTER (A64281)
UNUSED ATSPOWER...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
JLG 8ft Boom Lift Man Basket Attachment (A61572)
JLG 8ft Boom Lift...
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
