Snow JD 1025r Front Mount Snow Blower Instilation
   / JD 1025r Front Mount Snow Blower Instilation #1
Bundi
Cumberland, RI
JD 1025r FILB
Just wanted to post a note about the instillation of a front mount snow blower on my 1025r. It is very easy to convert over but am a little disappointed that I had to remove my MMM Hydraulic lift to get the drive shaft attached. I think I could have just put the lift in the full down position but then would run the chance of it being jammed up into the shaft.
I think I had to remove the lift - anyone know if I should have just dropped it into the down position and called it a day?
Beside removing the lift the rest of the instillation was about 20 min because the freaking thing ways a TON :)
   / JD 1025r Front Mount Snow Blower Instilation #2
If you're switching from mowing to blowing a lot, you could modify your MMM lift arms for manual connect. It would allow you to keep the MMM lift in place while you snow blow. If it's just once a year, be happy with AutoConnect!
   / JD 1025r Front Mount Snow Blower Instilation #3
Bundi,
You do NOT need to remove the hydraulic lift. You do need to remove the rear shaft/rod that runs side to side. It has a 18 mm hex nut on each end. Sorry I don't know the metric crap to say the correct thread size. But anyway just remove that shaft/rod will require one side lift arm to have a pin dropped down to get enough clearance to extract the shaft. Return the lift arm and pin as the rest can stay in place. I just finished installing my blower on 1023E.
Now if you have automatic driveshaft coupling, that has to be removed.
Bundi,
Thank you - That is what I was going to do but the JD person convinced me that because of the pins on the Hydraulic lift it would be easier to just remove the entire lift. I like your way much better
   / JD 1025r Front Mount Snow Blower Instilation #5
It would make no sense to remove the entire lift. Only the shaft/rod I mentioned is in the way. Good to be able to share what I found was an easier way. If JD had designed the shaft/rod with an offset to clear the blower drive shaft it could have stayed assembled.
   / JD 1025r Front Mount Snow Blower Instilation #6
Bundi....genesusie is correct - I just did this on my 1026R for the first time last weekend. Leave the lift kit on except for the cross bar. I found the easiest way to get it out is take off the left side lift bracket, pull out the cross bar & drive shaft.
I called my dealer & he confirmed this is the easiest way to do it.
John Deere 7130 (A53314)
John Deere 7130...
2020 John Deere HPX615E Gator 4x4 Utility Cart (A55787)
2020 John Deere...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56129)
2018 FREIGHTLINER...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2019 INTERNATIONAL RH613 SINGLE AXLE DAY CAB (A56129)
2019 INTERNATIONAL...
