Snow JD 1025r Front Mount Snow Blower Instilation
   / JD 1025r Front Mount Snow Blower Instilation #1
Bundi
Cumberland, RI
JD 1025r FILB
Just wanted to post a note about the instillation of a front mount snow blower on my 1025r. It is very easy to convert over but am a little disappointed that I had to remove my MMM Hydraulic lift to get the drive shaft attached. I think I could have just put the lift in the full down position but then would run the chance of it being jammed up into the shaft.
I think I had to remove the lift - anyone know if I should have just dropped it into the down position and called it a day?
Beside removing the lift the rest of the instillation was about 20 min because the freaking thing ways a TON :)
   / JD 1025r Front Mount Snow Blower Instilation #2
If you're switching from mowing to blowing a lot, you could modify your MMM lift arms for manual connect. It would allow you to keep the MMM lift in place while you snow blow. If it's just once a year, be happy with AutoConnect!
   / JD 1025r Front Mount Snow Blower Instilation #3
Bundi,
You do NOT need to remove the hydraulic lift. You do need to remove the rear shaft/rod that runs side to side. It has a 18 mm hex nut on each end. Sorry I don't know the metric crap to say the correct thread size. But anyway just remove that shaft/rod will require one side lift arm to have a pin dropped down to get enough clearance to extract the shaft. Return the lift arm and pin as the rest can stay in place. I just finished installing my blower on 1023E.
Now if you have automatic driveshaft coupling, that has to be removed.
Bundi,
Thank you - That is what I was going to do but the JD person convinced me that because of the pins on the Hydraulic lift it would be easier to just remove the entire lift. I like your way much better
   / JD 1025r Front Mount Snow Blower Instilation #5
It would make no sense to remove the entire lift. Only the shaft/rod I mentioned is in the way. Good to be able to share what I found was an easier way. If JD had designed the shaft/rod with an offset to clear the blower drive shaft it could have stayed assembled.
   / JD 1025r Front Mount Snow Blower Instilation #6
Bundi....genesusie is correct - I just did this on my 1026R for the first time last weekend. Leave the lift kit on except for the cross bar. I found the easiest way to get it out is take off the left side lift bracket, pull out the cross bar & drive shaft.
I called my dealer & he confirmed this is the easiest way to do it.
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
IRGC40 High-End Mini Golf Cart (A53316)
IRGC40 High-End...
20'x20' High End Carport (A53316)
20'x20' High End...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
