jcb backhoe brake question
/ jcb backhoe brake question #1
chrisdvorak
RI
too many
I have a 1987 JCB 1550b backhoe, I need to check the brake fluid because I think its low. I was looking in the manual and it said to unscrew the cover to check to see if the fluid is between the marks. seems simple enough but they don't tell you where the cover is, does anyone have this machine or something similar?
-thanks chris
/ jcb backhoe brake question #2
On my 1988 JCB 1400B the master cylinders and brake fluid reservoirs are located under a black plastic cover behind the instrument panel, next to the front glass. If the fluid is low, remember that these JCB's use light oil, not brake fluid in the brake system. Good luck.
thanks, I'll check it out
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
11' x 19' Metal Carport (A66408)
11' x 19' Metal...
