Jbar HD 5ft cutter
/ Jbar HD 5ft cutter #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
16177752_1346167908780595_6994670791979766458_o.jpg What do you think of this cutter? If you say it is cheap what makes it cheap? It has 7 gauge deck, 40hp gear box.I can weld extra bracing on top of deck if that would make it better.I don't see the difference from this cutter than others.I have read most cutters use the same gear boxes.I would be using it for grass no heavy brush.It weighs over 500lbs.it is made from US steel.please give reason for your opinions. Thanks! Would love to hear from one that has the HD model.The price is $785 on there facebook page.I am waitting to get email from them.
/ Jbar HD 5ft cutter #2
A 40 HP gearbox is not heavy duty. Brown cutters only have 120HP gearboxes. They call that medium duty. My 6' Brown weighs over 1100# and their 5' cutters are over 1000#. The Bush Hog 305's and 306's put them on the map. They were fitted with 90 HP gearboxes Nothing wrong with the J Bar but it is not heavy duty.
That Brown is a beast! I looked at bushhog brand, Landpride,King kutter. The J-bar has thicker steel.Maybe the blade tip speed is slower.I will check with J-bar.
/ Jbar HD 5ft cutter #4
Hey SCWOOD,
Did you end up getting the HD JBar? I am looking at them as well. Wanted to know your opinion.
Hey SCWOOD,
No not yet.Place I work is moving to Mexico.Having to put things like that on hold.I still a have 4' King kutter.
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2023 Case TV620B (A64119)
2023 Case TV620B...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
Caterpillar D4 Dozer Parts and Service Manuals (A63117)
Caterpillar D4...
