Jbar HD 5ft cutter
/ Jbar HD 5ft cutter #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
16177752_1346167908780595_6994670791979766458_o.jpg What do you think of this cutter? If you say it is cheap what makes it cheap? It has 7 gauge deck, 40hp gear box.I can weld extra bracing on top of deck if that would make it better.I don't see the difference from this cutter than others.I have read most cutters use the same gear boxes.I would be using it for grass no heavy brush.It weighs over 500lbs.it is made from US steel.please give reason for your opinions. Thanks! Would love to hear from one that has the HD model.The price is $785 on there facebook page.I am waitting to get email from them.
/ Jbar HD 5ft cutter #2
A 40 HP gearbox is not heavy duty. Brown cutters only have 120HP gearboxes. They call that medium duty. My 6' Brown weighs over 1100# and their 5' cutters are over 1000#. The Bush Hog 305's and 306's put them on the map. They were fitted with 90 HP gearboxes Nothing wrong with the J Bar but it is not heavy duty.
That Brown is a beast! I looked at bushhog brand, Landpride,King kutter. The J-bar has thicker steel.Maybe the blade tip speed is slower.I will check with J-bar.
/ Jbar HD 5ft cutter #4
Hey SCWOOD,
Did you end up getting the HD JBar? I am looking at them as well. Wanted to know your opinion.
Hey SCWOOD,
No not yet.Place I work is moving to Mexico.Having to put things like that on hold.I still a have 4' King kutter.
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2017 Nissan Quest Van (A61574)
2017 Nissan Quest...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
Geringhoff John Deere Adapter Kit (A63117)
Geringhoff John...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
